This should be a real easy on for you.
I need a common MOSFET TO-92 case if possible.
The transistor I am replacing is an Darlington NPN that is outdated and very costly
Looking for a part that will take a single TTL input and drive a 6V 500ma lamp.
I'm sure there are hundreds, Just need a few common ones to test to see it they will work.
Leg config. not a consideration, 3 leads (TO-92)
Cheap is better :{),
Best to you
Eric
