TINA/Spice/CSD87355Q5D: MOSFET Power Loss Calculator vs. SPICE
Part Number: CSD87355Q5D
Other Parts Discussed in Thread: TINA-TI,
Tool/software: TINA-TI or Spice Models
for a project I am trying to calculate switching losses in MOSFETs for different currents and frequencies.
As a test object I have chosen the part CSD87355Q5D. My first goal was to analytically calculate (http://www.ti.com/lit/an/slpa009a/slpa009a.pdfthe losses and compare them with the results given from the online tool "MOSFET Power Loss Calculator". This works fine.
Afterwards I wanted to build the same model in SPICE to compare the results to the calculated results (it is not really necessary, however, it's always good to cross-check). Unfortunately, the simulated losses do not correspond with the calculated losses.
Comparison:
MOSFET Power Loss Calculator:
SPICE Model (loss results from dissipated power W):
Does anyone has a clue if I am doing something wrong or is the SPICE Model not working properly?
Since I am rather new to this field, it might also be a strange question. Maybe it is simply not possible to do it like this?
Anyway, I would be happy about any help.
Reto
  • Reto,
    I am looking into this for you. To confirm - your manually calculated losses mostly agreed with the online calculator, correct? It was just the spice model simulation that did not correspond and looks like came in much lower.
  • Reto,
    Our apps team advises against using SPICE models for power loss estimations. The SPICE model isn't designed for this purpose, and a lot of the parameters are not calibrated to match the real values for Ploss.
    Assuming your manual calculations and the online calculator were in decent agreement, I would trust those losses more. And since they are higher, it will force you to be more conservative in your design.
  • Brett,
    Thank you very much for this fast answer.
    Yes, my manual calculations and the results from the online calculator are in agreement. As you suggested, I will take these calculations for further designing.
    Once again, thank you very much. I highly appreciate this.
    Reto
