Where can I get the thermal analysis parameters for the LM2674 (Psi-JT et al.)? And just for my curiosity, why is the information so hard to find?
Thanks!
Thanks!
During an internal design review, I discovered that another engineer requested this same data and he received an email from TI stating that the Psi JT is 4.6. The data I received via this forum is Psi JT = 9.2 (exactly twice the other value). Can you verify which number we should be using for the SOIC-8 package (I believe the datasheet refers to it as the D Pkg)? I also recall that you mentioned that the 9.2 value came from a part with a smaller die and might be pessimistic. Could that be the reason for the discrepancy?
Thanks!
Mike
