TPS3422 active timer current
Other Parts Discussed in Thread: TPS3420, TPS3422
Why is the active current of the TPS3422 (106uA) so much higher than the TPS3420/21 (6uA) or is this an error in the data sheet?
Rick
  • Hi Rick,
    The datasheet is correct. The additional current reflected in TPS3422 is the current through a pullup resistor between the input pin (PB1) and the supply pin (VCC). This is mentioned in a footnote at the bottom of the Electrical Characteristics table.
    Very Respectfully,
    Ryan
