Other Parts Discussed in Thread: TL7715A, , TPS3700, TPS3702, TPS3701
We use the TL7705B to monitor a couple of 5V rails and would like to adapt it to monitor a 15V rail (the TL7715A doesn't have the needed temp range for us and we already use the TL7705).
We would add a series resistor to the 15V rail into the sense input of the part. I've seen datasheets for this part that state that R1 and R2 in the sense resistor divider are 23Kohms and 10Kohms respectively, is this accurate? The datasheet on TI.com doesn't have a note 1 as the resistors call out.
I also want to understand the tolerance on the resistors. The electrical characteristics table trip tolerance gives some idea of how they vary in relation to each other but not their absolute tolerance.
Jake
