I want to receive the default PMP9444 Code for UCD90120ARGC.
Other Parts Discussed in Thread: UCD90120A
Hi , all.
I have design the FPGA Board using Xilinx Ultrascale FPGA.
While the circuit design , I found TI's Power Solution PMP9444.
Here , I have some question.
1. May I receive the PMP9444  default Code using USB GPIO Board. (PMBUS interface )
    First, I will use your Reference Design and Sequence.  So, I want to receive the default PMP9444 Code for UCD90120ARGC.
2. I wish to receive the PMP9444 Reference Board.  If you have this Board , Please give to me.
    I hope to test this board  before my board fabrication.
I hope to receive your reply quickly.
  • Hi Kim,
    Attached is the UCD90120A configuration file. You may need to double check the “Iout Cal Gain” and “Temp Cal Gain” settings for accurate current and temperature measurements.
    PMP9444 is reference design and not available online to ship. Customers will need to build up the board themselves with the file provided online.
    Zhiyuan
    UCD90120A.zip
