Good evening, I'm sorry for my question, but I have read on this community the same problems about
BQ51050B even if I have read many answers but I want to understand better.
Please, could you help me? I'm doing a thesis here at Politecnico of Torino and I have to use this
chip because I have to charge my LiPo battery (4.2V, 1100mAh).
I have so many problems and I have to solve them quickly:
1) Ros value. What kind of calibration process I have to use in order to figure out
the right value of Ros?
I'm disperate and I've read the datasheet at least 10 times. I put a 42.2kohms resistor.
Is it right?
2) I have chosen this coil of Vishay: http://www.vishay.com/docs/34376/iwas4832fe50.pdf
I can't do the measure of Ls and Ls' . It can be right if I put C1=137nF and C2=1.6nF?
I take the value from this example at pag.61 of this document:
http://www.y-adagio.com/public/committees/iec_tc100_ags/meetings/29/100ags438.pdf
3) C4 = 100uF (before the battery) and C3 = 10uF (after rect) They could be ok?
I'm worried about the point 2. I hope that it can be right.
Sorry for my english and Thank you for attention and I hope that you can help me. Best regards. Lacirignola Federica
