We are designing the board for an application for your bq51025EVM-649 using your layout example.
We cannot find a manufacturing plant to make the boards with through hole vias of 0.15mm in a pad of 0.25 mm.
We have your application board in hand, so we assume that it is the same as the gerbers you supplied.
Please recommend a PCB plant that can manufacture these boards.
