Part Number: PROCESSOR-SDK-AM335X
Hi, am compiling uboot using Yocto build system. The Yocto version am using is Rocko. I am unable to compile MLO/UBoot after adding a certain code. This code is related to crypto authentication chip ATECC508A. If I comment the code I am able to compile MLO/UBoot successfully.
Below is the log of the error which am facing.
./yocto_build build uboot
Command: TOOLCHAIN_PATH=/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/ MACHINE=am335x-evm bitbake virtual/bootloader
NOTE: Started PRServer with DBfile: /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 37777, PID: 11813
Loading cache: 100% |#####################################################################################################################################| Time: 0:00:00
Loaded 4500 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.36.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "arm-linux-gnueabi"
MACHINE = "am335x-evm"
DISTRO = "arago"
DISTRO_VERSION = "2018.08"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-arago-distro
meta-arago-extras = "rocko:44a7ac9ae43370f9140bd635068e07b8ea754f6c"
meta-browser = "HEAD:26d50665e2f7223c5f4ad7481a8d2431e7cb55fb"
meta-qt5 = "rocko:682ad61c071a9710e9f9d8a32ab1b5f3c14953d1"
meta-networking
meta-python
meta-perl
meta-oe
meta-gnome = "rocko:d54d9defd8da2a64a8a51437e8da465fd27adcb8"
meta-ti = "rocko:777b4f52614b89ae10fcc2f0bbdaed0cccff36bc"
meta-linaro-toolchain
meta-optee = "rocko:75dfb67bbb14a70cd47afda9726e2e1c76731885"
meta-java = "rocko:fbe0b0eb30d93f5fa2101fb015f20c1dc118b4a6"
meta-iot-cloud = "rocko:fef3f11ee69798c86777df5a6fb6a5248cc9cd26"
meta-security-compliance
meta-tpm
meta-security = "rocko:74860b2b61afd033fba130044ae66567ead57aaf"
meta-maker = "rocko:110266202eb52e8d7089627154e885d72fdc6f7b"
meta = "rocko:2c19958d33e972b72177b159727c8fc29957eb99"
Initialising tasks: 100% |################################################################################################################################| Time: 0:00:00
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: u-boot-ti-staging-2018.01+gitAUTOINC+8b2f1df4b5-r19 do_compile: oe_runmake failed
ERROR: u-boot-ti-staging-2018.01+gitAUTOINC+8b2f1df4b5-r19 do_compile: Function failed: do_compile (log file is located at /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/temp/log.do_compile.11879)
ERROR: Logfile of failure stored in: /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/temp/log.do_compile.11879
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 6 CROSS_COMPILE=arm-linux-gnueabihf- CC=arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot V=1 HOSTCC=gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -C /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git O=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/build am335x_evm_config
| make: Entering directory '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git'
| make -C /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/build KBUILD_SRC=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git \
| -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/Makefile am335x_evm_config
| make[1]: Entering directory '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/build'
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=scripts/basic
| ln -fsn /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git source
| rm -f .tmp_quiet_recordmcount
| /bin/sh /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/mkmakefile \
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git . 2018 01
| GEN ./Makefile
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=scripts/kconfig am335x_evm_config
| scripts/kconfig/conf --defconfig=arch/../configs/am335x_evm_defconfig Kconfig
| # configuration written to .config
| make[1]: Leaving directory '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/build'
| make: Leaving directory '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git'
| NOTE: make -j 6 CROSS_COMPILE=arm-linux-gnueabihf- CC=arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot V=1 HOSTCC=gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -C /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git O=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/build all
| -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/Makefile all
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/Makefile silentoldconfig
| GEN ./Makefile
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=scripts/kconfig silentoldconfig
| mkdir -p include/config include/generated
| test -e include/generated/autoksyms.h || \
| touch include/generated/autoksyms.h
| scripts/kconfig/conf --silentoldconfig Kconfig
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.autoconf || \
| { rm -f include/config/auto.conf; false; }
| mkdir -p include/asm
| if [ -d /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-am33xx/include/mach ]; then \
| dest=arch/arm/mach-am33xx/include/mach; \
| else \
| dest=arch/arm/include/asm/arch-am33xx; \
| fi; \
| ln -fsn /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/$dest include/asm/arch
| set -e; : ' CHK include/config.h'; mkdir -p include/; (echo "/* Automatically generated - do not edit */"; for i in $(echo "" | sed 's/,/ /g'); do echo \#define CONFIG_$i | sed '/=/ {s/=/ /;q; } ; { s/$/ 1/; }'; done; echo \#define CONFIG_BOARDDIR board/ti/am335x; echo \#include \<config_defaults.h\>; echo \#include \<config_uncmd_spl.h\>; echo \#include \<configs/"am335x_evm".h\>; echo \#include \<asm/config.h\>; echo \#include \<linux/kconfig.h\>; echo \#include \<config_fallbacks.h\>;) < /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.autoconf > include/config.h.tmp; if [ -r include/config.h ] && cmp -s include/config.h include/config.h.tmp; then rm -f include/config.h.tmp; else : ' UPD include/config.h'; mv -f include/config.h.tmp include/config.h; fi
| mkdir -p spl/
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -E -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -DDO_DEPS_ONLY -dM /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/common.h > u-boot.cfg.tmp && { grep 'define CONFIG_' u-boot.cfg.tmp > u-boot.cfg; rm u-boot.cfg.tmp; } || { rm u-boot.cfg.tmp; false; }
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -x c -DDO_DEPS_ONLY -M -MP -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -MQ include/config/auto.conf /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/common.h > include/autoconf.mk.dep || { rm include/autoconf.mk.dep; false; }
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -E -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -DCONFIG_SPL_BUILD -DDO_DEPS_ONLY -dM /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/common.h > spl/u-boot.cfg.tmp && { grep 'define CONFIG_' spl/u-boot.cfg.tmp > spl/u-boot.cfg; rm spl/u-boot.cfg.tmp; } || { rm spl/u-boot.cfg.tmp; false; }
| mkdir -p spl/include/
| sed -n -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/scripts/define2mk.sed u-boot.cfg | while read line; do if [ -n "" ] || ! grep -q "${line%=*}=" include/config/auto.conf; then echo "$line"; fi done > include/autoconf.mk
| sed -n -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/scripts/define2mk.sed spl/u-boot.cfg | while read line; do if [ -n "" ] || ! grep -q "${line%=*}=" include/config/auto.conf; then echo "$line"; fi done > spl/include/autoconf.mk
| touch include/config/auto.conf
| set -e; : ' CHK include/config/uboot.release'; mkdir -p include/config/; echo "2018.01$(/bin/sh /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/setlocalversion /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git)" < include/config/auto.conf > include/config/uboot.release.tmp; if [ -r include/config/uboot.release ] && cmp -s include/config/uboot.release include/config/uboot.release.tmp; then rm -f include/config/uboot.release.tmp; else : ' UPD include/config/uboot.release'; mv -f include/config/uboot.release.tmp include/config/uboot.release; fi
| set -e; : ' CHK include/generated/timestamp_autogenerated.h'; mkdir -p include/generated/; (if test -n "${SOURCE_DATE_EPOCH}"; then SOURCE_DATE="@${SOURCE_DATE_EPOCH}"; DATE=""; for date in gdate date.gnu date; do ${date} -u -d "${SOURCE_DATE}" >/dev/null 2>&1 && DATE="${date}"; done; if test -n "${DATE}"; then LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TIME "%T"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TZ "%z"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_BUILD_DATE 0x%Y%m%d'; else return 42; fi; else LC_ALL=C date +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C date +'#define U_BOOT_TIME "%T"'; LC_ALL=C date +'#define U_BOOT_TZ "%z"'; LC_ALL=C date +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; LC_ALL=C date +'#define U_BOOT_BUILD_DATE 0x%Y%m%d'; fi) < /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/Makefile > include/generated/timestamp_autogenerated.h.tmp; if [ -r include/generated/timestamp_autogenerated.h ] && cmp -s include/generated/timestamp_autogenerated.h include/generated/timestamp_autogenerated.h.tmp; then rm -f include/generated/timestamp_autogenerated.h.tmp; else : ' UPD include/generated/timestamp_autogenerated.h'; mv -f include/generated/timestamp_autogenerated.h.tmp include/generated/timestamp_autogenerated.h; fi
| GEN ./Makefile
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.autoconf u-boot.cfg
| if [ -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/.config -o -d /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/config ]; then \
| echo >&2 " /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git is not clean, please run 'make mrproper'"; \
| echo >&2 " in the '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git' directory.";\
| /bin/false; \
| fi;
| set -e; : ' CHK include/generated/version_autogenerated.h'; mkdir -p include/generated/; (echo \#define PLAIN_VERSION \"2018.01""-g552e7da15c\"; echo \#define U_BOOT_VERSION \"U-Boot \" PLAIN_VERSION; echo \#define CC_VERSION_STRING \"$(LC_ALL=C arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot --version | head -n 1)\"; echo \#define LD_VERSION_STRING \"$(LC_ALL=C arm-linux-gnueabihf-ld.bfd --version | head -n 1)\"; ) < include/config/uboot.release > include/generated/version_autogenerated.h.tmp; if [ -r include/generated/version_autogenerated.h ] && cmp -s include/generated/version_autogenerated.h include/generated/version_autogenerated.h.tmp; then rm -f include/generated/version_autogenerated.h.tmp; else : ' UPD include/generated/version_autogenerated.h'; mv -f include/generated/version_autogenerated.h.tmp include/generated/version_autogenerated.h; fi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=scripts/dtc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=.
| mkdir -p lib/
| mkdir -p arch/arm/lib/
| set -e; : ' CHK include/generated/generic-asm-offsets.h'; mkdir -p include/generated/; (set -e; echo "#ifndef __GENERIC_ASM_OFFSETS_H__"; echo "#define __GENERIC_ASM_OFFSETS_H__"; echo "/*"; echo " * DO NOT MODIFY."; echo " *"; echo " * This file was generated by Kbuild"; echo " */"; echo ""; sed -ne "s:[[:space:]]*\.ascii[[:space:]]*\"\(.*\)\":\1:; /^->/{s:->#\(.*\):/* \1 */:; s:^->\([^ ]*\) [\$#]*\([-0-9]*\) \(.*\):#define \1 \2 /* \3 */:; s:^->\([^ ]*\) [\$#]*\([^ ]*\) \(.*\):#define \1 \2 /* \3 */:; s:->::; p;}"; echo ""; echo "#endif" ) < lib/asm-offsets.s > include/generated/generic-asm-offsets.h.tmp; if [ -r include/generated/generic-asm-offsets.h ] && cmp -s include/generated/generic-asm-offsets.h include/generated/generic-asm-offsets.h.tmp; then rm -f include/generated/generic-asm-offsets.h.tmp; else : ' UPD include/generated/generic-asm-offsets.h'; mv -f include/generated/generic-asm-offsets.h.tmp include/generated/generic-asm-offsets.h; fi
| set -e; : ' CHK include/generated/asm-offsets.h'; mkdir -p include/generated/; (set -e; echo "#ifndef __ASM_OFFSETS_H__"; echo "#define __ASM_OFFSETS_H__"; echo "/*"; echo " * DO NOT MODIFY."; echo " *"; echo " * This file was generated by Kbuild"; echo " */"; echo ""; sed -ne "s:[[:space:]]*\.ascii[[:space:]]*\"\(.*\)\":\1:; /^->/{s:->#\(.*\):/* \1 */:; s:^->\([^ ]*\) [\$#]*\([-0-9]*\) \(.*\):#define \1 \2 /* \3 */:; s:^->\([^ ]*\) [\$#]*\([^ ]*\) \(.*\):#define \1 \2 /* \3 */:; s:->::; p;}"; echo ""; echo "#endif" ) < arch/arm/lib/asm-offsets.s > include/generated/asm-offsets.h.tmp; if [ -r include/generated/asm-offsets.h ] && cmp -s include/generated/asm-offsets.h include/generated/asm-offsets.h.tmp; then rm -f include/generated/asm-offsets.h.tmp; else : ' UPD include/generated/asm-offsets.h'; mv -f include/generated/asm-offsets.h.tmp include/generated/asm-offsets.h; fi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=tools
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -Wp,-MD,tools/.mkenvimage.o.d -Itools -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/libfdt_env.h -idirafterinclude -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/dtc/libfdt -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -c -o tools/mkenvimage.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/mkenvimage.c
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -Wp,-MD,tools/.fit_image.o.d -Itools -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/libfdt_env.h -idirafterinclude -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/dtc/libfdt -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -DMKIMAGE_DTC=\""dtc"\" -c -o tools/fit_image.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/fit_image.c
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -Wp,-MD,tools/.image-host.o.d -Itools -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/libfdt_env.h -idirafterinclude -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/dtc/libfdt -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -c -o tools/image-host.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/image-host.c
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -Wp,-MD,tools/.mkimage.o.d -Itools -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/libfdt_env.h -idirafterinclude -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/dtc/libfdt -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -c -o tools/mkimage.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/mkimage.c
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -Wp,-MD,tools/.dumpimage.o.d -Itools -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/libfdt_env.h -idirafterinclude -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -idirafter/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/dtc/libfdt -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE -c -o tools/dumpimage.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/tools/dumpimage.c
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -o tools/mkenvimage tools/mkenvimage.o tools/os_support.o tools/lib/crc32.o
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -o tools/dumpimage tools/aisimage.o tools/atmelimage.o tools/common/bootm.o tools/lib/crc32.o tools/default_image.o tools/lib/fdtdec_common.o tools/lib/fdtdec.o tools/fit_common.o tools/fit_image.o tools/common/image-fit.o tools/image-host.o tools/common/image.o tools/imagetool.o tools/imximage.o tools/kwbimage.o tools/lib/md5.o tools/lpc32xximage.o tools/mxsimage.o tools/omapimage.o tools/os_support.o tools/pblimage.o tools/pbl_crc32.o tools/vybridimage.o tools/lib/rc4.o tools/rkcommon.o tools/rkimage.o tools/rksd.o tools/rkspi.o tools/socfpgaimage.o tools/lib/sha1.o tools/lib/sha256.o tools/common/hash.o tools/ublimage.o tools/zynqimage.o tools/zynqmpimage.o tools/libfdt/fdt.o tools/libfdt/fdt_wip.o tools/libfdt/fdt_sw.o tools/libfdt/fdt_strerror.o tools/libfdt/fdt_empty_tree.o tools/libfdt/fdt_addresses.o tools/libfdt/fdt_overlay.o tools/lib/libfdt/fdt_ro.o tools/lib/libfdt/fdt_rw.o tools/lib/libfdt/fdt_region.o tools/gpimage.o tools/gpimage-common.o tools/dumpimage.o
| gcc -isystem/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/include -O2 -pipe -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -L/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot-native/lib -Wl,-O1 -o tools/mkimage tools/aisimage.o tools/atmelimage.o tools/common/bootm.o tools/lib/crc32.o tools/default_image.o tools/lib/fdtdec_common.o tools/lib/fdtdec.o tools/fit_common.o tools/fit_image.o tools/common/image-fit.o tools/image-host.o tools/common/image.o tools/imagetool.o tools/imximage.o tools/kwbimage.o tools/lib/md5.o tools/lpc32xximage.o tools/mxsimage.o tools/omapimage.o tools/os_support.o tools/pblimage.o tools/pbl_crc32.o tools/vybridimage.o tools/lib/rc4.o tools/rkcommon.o tools/rkimage.o tools/rksd.o tools/rkspi.o tools/socfpgaimage.o tools/lib/sha1.o tools/lib/sha256.o tools/common/hash.o tools/ublimage.o tools/zynqimage.o tools/zynqmpimage.o tools/libfdt/fdt.o tools/libfdt/fdt_wip.o tools/libfdt/fdt_sw.o tools/libfdt/fdt_strerror.o tools/libfdt/fdt_empty_tree.o tools/libfdt/fdt_addresses.o tools/libfdt/fdt_overlay.o tools/lib/libfdt/fdt_ro.o tools/lib/libfdt/fdt_rw.o tools/lib/libfdt/fdt_region.o tools/gpimage.o tools/gpimage-common.o tools/mkimage.o
| else \
| fi; \
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/cpu
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/cpu/armv7
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/lib
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/mach-omap2
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=board/ti/am335x
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=board/ti/common
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=cmd
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=common
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,board/ti/am335x/.board.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/board/ti/am335x -Iboard/ti/am335x -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(board)" -D"KBUILD_MODNAME=KBUILD_STR(board)" -c -o board/ti/am335x/board.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/board/ti/am335x/board.c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=disk
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/mach-omap2/am33xx
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/dma
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/board/ti/am335x/board.c: In function 'board_late_init':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/board/ti/am335x/board.c:799:9: warning: variable 'ret' set but not used [-Wunused-but-set-variable]
| int ret = 0;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/board/ti/am335x/board.c:798:19: warning: unused variable 'data' [-Wunused-variable]
| unsigned char data = 0x00;
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,cmd/.version.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/cmd -Icmd -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(version)" -D"KBUILD_MODNAME=KBUILD_STR(version)" -c -o cmd/version.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/cmd/version.c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/dma/ti
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/gpio
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/adc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/i2c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/ata
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=cmd/ti
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/block
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=common/init
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,common/.main.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common -Icommon -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(main)" -D"KBUILD_MODNAME=KBUILD_STR(main)" -c -o common/main.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/main.c
| arm-linux-gnueabihf-ld.bfd -r -o board/ti/am335x/built-in.o board/ti/am335x/board.o
| arm-linux-gnueabihf-ld.bfd -r -o cmd/built-in.o cmd/boot.o cmd/bootm.o cmd/help.o cmd/version.o cmd/blk_common.o cmd/source.o cmd/bdinfo.o cmd/bootefi.o cmd/bootz.o cmd/console.o cmd/echo.o cmd/eeprom.o cmd/elf.o cmd/exit.o cmd/ext4.o cmd/ext2.o cmd/fat.o cmd/fdt.o cmd/fs.o cmd/gpio.o cmd/i2c.o cmd/itest.o cmd/load.o cmd/mem.o cmd/mii.o cmd/mdio.o cmd/misc.o cmd/mmc.o cmd/mtdparts.o cmd/nand.o cmd/net.o cmd/part.o cmd/pcmcia.o cmd/pxe.o cmd/sf.o cmd/spi.o cmd/time.o cmd/test.o cmd/usb.o cmd/disk.o cmd/fastboot.o cmd/ximg.o cmd/spl.o cmd/dfu.o cmd/gpt.o cmd/nvedit.o cmd/ti/built-in.o
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/mtd
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/bootcount
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/core
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/mtd/nand
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,common/.crypto.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common -Icommon -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(crypto)" -D"KBUILD_MODNAME=KBUILD_STR(crypto)" -c -o common/crypto.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/mtd/onenand
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/crypto
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/crypto/fsl
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/mtd/spi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/crypto/rsa_mod_exp
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/dfu
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'sha256_hash_string':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:74:13: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness [-Wpointer-sign]
| sprintf(outputBuffer + (i * 2), "%02x", (unsigned char)hash[i]);
| In file included from /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/bug.h:4:0,
| from /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/common.h:26,
| from /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:1:
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/vsprintf.h:109:5: note: expected 'char *' but argument is of type 'uint8_t * {aka unsigned char *}'
| int sprintf(char *buf, const char *fmt, ...)
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'sha256_file':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:128:28: warning: pointer targets in passing argument 2 of 'sha256_update' differ in signedness [-Wpointer-sign]
| sha256_update(&sha256, buffer, bufSize);
| In file included from /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:10:0:
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/u-boot/sha256.h:19:6: note: expected 'const uint8_t * {aka const unsigned char *}' but argument is of type 'char *'
| void sha256_update(sha256_context *ctx, const uint8_t *input, uint32_t length);
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'i2c_send':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:205:7: warning: unused variable 'i' [-Wunused-variable]
| int i = 0;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'i2c_receive':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:246:7: warning: unused variable 'i' [-Wunused-variable]
| int i = 0;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'do_generate_key':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:354:7: warning: unused variable 'i' [-Wunused-variable]
| int i = 0;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'write_data_i2c':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:431:20: warning: unused variable 'crc' [-Wunused-variable]
| uint8_t length, *crc;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:431:11: warning: unused variable 'length' [-Wunused-variable]
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'do_sign_msg':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:582:7: warning: unused variable 'i' [-Wunused-variable]
| int i = 0;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c: In function 'verify_signature':
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:756:8: warning: unused variable 'verified' [-Wunused-variable]
| bool verified = false;
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c:754:7: warning: unused variable 'err' [-Wunused-variable]
| int err = 0;
| arm-linux-gnueabihf-ld.bfd -r -o common/built-in.o common/init/built-in.o common/main.o common/exports.o common/hash.o common/cli_hush.o common/autoboot.o common/board_f.o common/board_r.o common/board_info.o common/bootm.o common/bootm_os.o common/fdt_support.o common/miiphyutil.o common/usb.o common/usb_hub.o common/usb_storage.o common/splash.o common/menu.o common/cli_readline.o common/cli_simple.o common/console.o common/dlmalloc.o common/malloc_simple.o common/image.o common/image-android.o common/image-fdt.o common/image-fit.o common/memsize.o common/stdio.o common/crypto.o common/cli.o common/dfu.o common/command.o common/s_record.o common/xyzModem.o
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/net
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/firmware
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/net/phy
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/input
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/mailbox
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/memory
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/misc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/pci
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/mmc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/pcmcia
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power/battery
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power/fuel_gauge
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/phy/marvell
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power/domain
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power/mfd
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/pwm
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/reset
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power/pmic
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/power/regulator
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/serial
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/spi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/rtc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/common
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/scsi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/soc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/sound
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/spmi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/dwc3
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/emul
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/sysreset
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/eth
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/gadget
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/thermal
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/gadget/udc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/timer
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/tpm
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/video
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/watchdog
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/host
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/video/bridge
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/video/sunxi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/musb-new
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/phy
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=drivers/usb/ulpi
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=env
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=fs
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,drivers/usb/gadget/.f_fastboot.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/drivers/usb/gadget -Idrivers/usb/gadget -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(f_fastboot)" -D"KBUILD_MODNAME=KBUILD_STR(f_fastboot)" -c -o drivers/usb/gadget/f_fastboot.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/drivers/usb/gadget/f_fastboot.c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=fs/ext4
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=fs/fat
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=net
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=test
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=test/dm
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib/efi_loader
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib/efi_selftest
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib/libfdt
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib/lzo
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib/rsa
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=lib/zlib
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,lib/.smbios.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib -Ilib -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(smbios)" -D"KBUILD_MODNAME=KBUILD_STR(smbios)" -c -o lib/smbios.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib/smbios.c
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,lib/efi_loader/.helloworld.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib/efi_loader -Ilib/efi_loader -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -mno-unaligned-access -fno-common -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -fpic -fshort-wchar -ffreestanding -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(helloworld)" -D"KBUILD_MODNAME=KBUILD_STR(helloworld)" -c -o lib/efi_loader/helloworld.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib/efi_loader/helloworld.c
| arm-linux-gnueabihf-ld.bfd -r -o drivers/usb/gadget/built-in.o drivers/usb/gadget/epautoconf.o drivers/usb/gadget/config.o drivers/usb/gadget/usbstring.o drivers/usb/gadget/g_dnl.o drivers/usb/gadget/f_dfu.o drivers/usb/gadget/f_fastboot.o drivers/usb/gadget/ether.o drivers/usb/gadget/rndis.o
| arm-linux-gnueabihf-ld.bfd -nostdlib -znocombreloc -T /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/lib/elf_arm_efi.lds -shared -Bsymbolic lib/efi_loader/helloworld.o arch/arm/lib/crt0_arm_efi.o arch/arm/lib/reloc_arm_efi.o -o lib/efi_loader/helloworld_efi.so
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,lib/.display_options.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib -Ilib -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(display_options)" -D"KBUILD_MODNAME=KBUILD_STR(display_options)" -c -o lib/display_options.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib/display_options.c
| arm-linux-gnueabihf-objcopy -j .header -j .text -j .sdata -j .data -j .dynamic -j .dynsym -j .rel* -j .rela* -j .reloc -O binary lib/efi_loader/helloworld_efi.so lib/efi_loader/helloworld.efi
| rm lib/efi_loader/helloworld.o lib/efi_loader/helloworld_efi.so
| arm-linux-gnueabihf-ld.bfd -r -o lib/built-in.o lib/efi_loader/built-in.o lib/efi_selftest/built-in.o lib/libfdt/built-in.o lib/charset.o lib/crc7.o lib/crc8.o lib/crc16.o lib/fdtdec_common.o lib/smbios.o lib/initcall.o lib/lmb.o lib/ldiv.o lib/md5.o lib/net_utils.o lib/qsort.o lib/rc4.o lib/list_sort.o lib/rsa/built-in.o lib/sha1.o lib/sha256.o lib/zlib/built-in.o lib/gunzip.o lib/lzo/built-in.o lib/fdtdec.o lib/hashtable.o lib/errno.o lib/display_options.o lib/crc32.o lib/ctype.o lib/div64.o lib/hang.o lib/linux_compat.o lib/linux_string.o lib/membuff.o lib/slre.o lib/string.o lib/tables_csum.o lib/time.o lib/uuid.o lib/rand.o lib/vsprintf.o lib/panic.o lib/strto.o lib/strmhz.o
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=examples
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=examples/standalone
| arm-linux-gnueabihf-ld.bfd -pie --gc-sections -Bstatic --no-dynamic-linker -Ttext 0x80800000 -o u-boot -T u-boot.lds arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/built-in.o arch/arm/cpu/armv7/built-in.o arch/arm/lib/built-in.o arch/arm/mach-omap2/built-in.o board/ti/am335x/built-in.o board/ti/common/built-in.o cmd/built-in.o common/built-in.o disk/built-in.o drivers/built-in.o drivers/dma/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/mtd/built-in.o drivers/mtd/nand/built-in.o drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o drivers/net/built-in.o drivers/net/phy/built-in.o drivers/pci/built-in.o drivers/power/built-in.o drivers/power/battery/built-in.o drivers/power/fuel_gauge/built-in.o drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o drivers/power/regulator/built-in.o drivers/serial/built-in.o drivers/spi/built-in.o drivers/usb/common/built-in.o drivers/usb/dwc3/built-in.o drivers/usb/emul/built-in.o drivers/usb/eth/built-in.o drivers/usb/gadget/built-in.o drivers/usb/gadget/udc/built-in.o drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o drivers/usb/musb/built-in.o drivers/usb/phy/built-in.o drivers/usb/ulpi/built-in.o env/built-in.o fs/built-in.o lib/built-in.o net/built-in.o test/built-in.o test/dm/built-in.o --end-group arch/arm/lib/eabi_compat.o arch/arm/lib/lib.a -Map u-boot.map; true
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=dts dtbs
| arm-linux-gnueabihf-objcopy --gap-fill=0xff -j .text -j .secure_text -j .secure_data -j .rodata -j .hash -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn -j .binman_sym_table -j .dtb.init.rodata -j .efi_runtime -j .efi_runtime_rel -O binary u-boot u-boot-nodtb.bin
| arm-linux-gnueabihf-objcopy --gap-fill=0xff -j .text -j .secure_text -j .secure_data -j .rodata -j .hash -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn -j .binman_sym_table -j .dtb.init.rodata -j .efi_runtime -j .efi_runtime_rel -O srec u-boot u-boot.srec
| arm-linux-gnueabihf-objdump -t u-boot > u-boot.sym
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/dts dtbs
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=arch/arm/dts arch/arm/dts/am335x-evm.dtb
| make[3]: 'arch/arm/dts/am335x-evm.dtb' is up to date.
| test -e arch/arm/dts/am335x-evm.dtb || ( \
| echo >&2; \
| echo >&2 "Device Tree Source is not correctly specified."; \
| echo >&2 "Please define 'CONFIG_DEFAULT_DEVICE_TREE'"; \
| echo >&2 "or build with 'DEVICE_TREE=<device_tree>' argument"; \
| echo >&2; \
| /bin/false)
| ./tools/mkimage -f auto -A arm -T firmware -C none -O u-boot -a 0x80800000 -e 0 -n "U-Boot 2018.01""-g552e7da15c for am335x board" -E -b arch/arm/dts/am335x-evm.dtb -b arch/arm/dts/am335x-bone.dtb -b arch/arm/dts/am335x-boneblack.dtb -b arch/arm/dts/am335x-evmsk.dtb -b arch/arm/dts/am335x-bonegreen.dtb -b arch/arm/dts/am335x-icev2.dtb -d u-boot-nodtb.bin u-boot.img
| make obj=spl -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.spl all
| cat u-boot-nodtb.bin dts/dt.dtb > u-boot-dtb.bin
| ./tools/mkimage -f auto -A arm -T firmware -C none -O u-boot -a 0x80800000 -e 0 -n "U-Boot 2018.01""-g552e7da15c for am335x board" -E -b arch/arm/dts/am335x-evm.dtb -b arch/arm/dts/am335x-bone.dtb -b arch/arm/dts/am335x-boneblack.dtb -b arch/arm/dts/am335x-evmsk.dtb -b arch/arm/dts/am335x-bonegreen.dtb -b arch/arm/dts/am335x-icev2.dtb -d u-boot-nodtb.bin u-boot-dtb.img
| cp u-boot-dtb.bin u-boot.bin
| FIT description: Firmware image with one or more FDT blobs
| Created: Wed Oct 3 06:25:19 2018
| Image 0 (firmware@1)
| Description: U-Boot 2018.01-g552e7da15c for am335x board
| Type: Firmware
| Compression: uncompressed
| Data Size: unavailable
| Architecture: ARM
| Load Address: 0x80800000
| Image 1 (fdt@1)
| Description: am335x-evm
| Type: Firmware
| Architecture: ARM
| Load Address: unavailable
| Image 2 (fdt@2)
| Description: am335x-bone
| Type: Firmware
| Architecture: ARM
| Image 3 (fdt@3)
| Description: am335x-boneblack
| Type: Firmware
| Architecture: ARM
| Image 4 (fdt@4)
| Description: am335x-evmsk
| Type: Firmware
| Architecture: ARM
| Image 5 (fdt@5)
| Description: am335x-bonegreen
| Type: Firmware
| Architecture: ARM
| Image 6 (fdt@6)
| Description: am335x-icev2
| Type: Firmware
| Architecture: ARM
| Default Configuration: 'conf@1'
| Configuration 0 (conf@1)
| Kernel: unavailable
| FDT: fdt@1
| Configuration 1 (conf@2)
| Kernel: unavailable
| FDT: fdt@2
| Configuration 2 (conf@3)
| Kernel: unavailable
| FDT: fdt@3
| Configuration 3 (conf@4)
| Kernel: unavailable
| FDT: fdt@4
| Configuration 4 (conf@5)
| Kernel: unavailable
| FDT: fdt@5
| Configuration 5 (conf@6)
| Kernel: unavailable
| FDT: fdt@6
| Type: Firmware
| Architecture: ARM
| Image 1 (fdt@1)
| Type: Firmware
| Architecture: ARM
| Image 2 (fdt@2)
| Type: Firmware
| Architecture: ARM
| Image 3 (fdt@3)
| Type: Firmware
| Architecture: ARM
| Image 4 (fdt@4)
| Type: Firmware
| Architecture: ARM
| Image 5 (fdt@5)
| Type: Firmware
| Architecture: ARM
| Image 6 (fdt@6)
| Type: Firmware
| Architecture: ARM
| Kernel: unavailable
| FDT: fdt@1
| Kernel: unavailable
| FDT: fdt@2
| Kernel: unavailable
| FDT: fdt@3
| Kernel: unavailable
| FDT: fdt@4
| Kernel: unavailable
| FDT: fdt@5
| Kernel: unavailable
| FDT: fdt@6
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/arch/arm/mach-omap2
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/arch/arm/cpu/armv7
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/arch/arm/lib
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/board/ti/am335x
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/board/ti/common
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/common/spl
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/common/init
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,spl/board/ti/am335x/.board.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/spl/board/ti/am335x -Ispl/board/ti/am335x -D__KERNEL__ -D__UBOOT__ -DCONFIG_SPL_BUILD -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -ffunction-sections -fdata-sections -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(board)" -D"KBUILD_MODNAME=KBUILD_STR(board)" -c -o spl/board/ti/am335x/board.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/board/ti/am335x/board.c
| int ret = 0;
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,spl/common/spl/.spl.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/spl/common/spl -Ispl/common/spl -D__KERNEL__ -D__UBOOT__ -DCONFIG_SPL_BUILD -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -ffunction-sections -fdata-sections -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(spl)" -D"KBUILD_MODNAME=KBUILD_STR(spl)" -c -o spl/common/spl/spl.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/spl/spl.c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/cmd
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/arch/arm/mach-omap2/am33xx
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/env
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,spl/common/.crypto.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/spl/common -Ispl/common -D__KERNEL__ -D__UBOOT__ -DCONFIG_SPL_BUILD -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -ffunction-sections -fdata-sections -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(crypto)" -D"KBUILD_MODNAME=KBUILD_STR(crypto)" -c -o spl/common/crypto.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/common/crypto.c
| int i = 0;
| int i = 0;
| int i = 0;
| int i = 0;
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/cmd/ti
| int err = 0;
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/lib
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/disk
| arm-linux-gnueabihf-ld.bfd -r -o spl/board/ti/am335x/built-in.o spl/board/ti/am335x/mux.o spl/board/ti/am335x/board.o
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers
| arm-linux-gnueabihf-ld.bfd -r -o spl/common/built-in.o spl/common/xyzModem.o spl/common/common_fit.o spl/common/miiphyutil.o spl/common/fdt_support.o spl/common/console.o spl/common/dlmalloc.o spl/common/malloc_simple.o spl/common/image.o spl/common/image-android.o spl/common/image-fdt.o spl/common/image-fit.o spl/common/memsize.o spl/common/stdio.o spl/common/crypto.o spl/common/cli.o spl/common/dfu.o spl/common/command.o spl/common/s_record.o
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/block
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/core
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/gpio
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/usb/dwc3
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/i2c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/dts
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/fs
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/mmc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/fs/ext4
| arm-linux-gnueabihf-ld.bfd -r -o spl/common/spl/built-in.o spl/common/spl/spl.o spl/common/spl/spl_fit.o spl/common/spl/spl_ymodem.o spl/common/spl/spl_nand.o spl/common/spl/spl_net.o spl/common/spl/spl_mmc.o spl/common/spl/spl_fat.o spl/common/spl/spl_ext.o
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/lib/libfdt
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/fs/fat
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/lib/rsa
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/mtd
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/net
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/mtd/nand
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/net
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/net/phy
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/power
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/power/pmic
| arm-linux-gnueabihf-gcc --sysroot=/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/recipe-sysroot -Wp,-MD,spl/lib/.display_options.o.d -nostdinc -isystem /opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/include -Iinclude -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/include -include /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/include/linux/kconfig.h -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/spl/lib -Ispl/lib -D__KERNEL__ -D__UBOOT__ -DCONFIG_SPL_BUILD -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fshort-wchar -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -ffunction-sections -fdata-sections -D__ARM__ -Wa,-mimplicit-it=always -mthumb -mthumb-interwork -mabi=aapcs-linux -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/arch/arm/mach-omap2/include -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(display_options)" -D"KBUILD_MODNAME=KBUILD_STR(display_options)" -c -o spl/lib/display_options.o /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/lib/display_options.c
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/power/regulator
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/serial
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/usb/gadget
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/usb/gadget/udc
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/usb/musb-new
| make -f /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.build obj=spl/drivers/watchdog
| arm-linux-gnueabihf-ld.bfd -r -o spl/lib/built-in.o spl/lib/rsa/built-in.o spl/lib/sha1.o spl/lib/sha256.o spl/lib/libfdt/built-in.o spl/lib/crc16.o spl/lib/net_utils.o spl/lib/hashtable.o spl/lib/errno.o spl/lib/display_options.o spl/lib/crc32.o spl/lib/ctype.o spl/lib/div64.o spl/lib/hang.o spl/lib/linux_compat.o spl/lib/linux_string.o spl/lib/membuff.o spl/lib/slre.o spl/lib/string.o spl/lib/tables_csum.o spl/lib/time.o spl/lib/uuid.o spl/lib/rand.o spl/lib/tiny-printf.o spl/lib/panic.o spl/lib/strto.o
| (cd spl && arm-linux-gnueabihf-ld.bfd -T u-boot-spl.lds --gc-sections -Bstatic --gc-sections --no-dynamic-linker -Ttext 0x402F0400 arch/arm/cpu/armv7/start.o --start-group arch/arm/mach-omap2/built-in.o arch/arm/cpu/armv7/built-in.o arch/arm/cpu/built-in.o arch/arm/lib/built-in.o board/ti/am335x/built-in.o board/ti/common/built-in.o common/spl/built-in.o common/init/built-in.o common/built-in.o cmd/built-in.o env/built-in.o lib/built-in.o disk/built-in.o drivers/built-in.o drivers/usb/dwc3/built-in.o dts/built-in.o fs/built-in.o net/built-in.o --end-group arch/arm/lib/eabi_compat.o arch/arm/lib/lib.a -Map u-boot-spl.map -o u-boot-spl)
| arm-linux-gnueabihf-ld.bfd: u-boot-spl section `.rodata' will not fit in region `.sram'
| arm-linux-gnueabihf-ld.bfd: region `.sram' overflowed by 8444 bytes
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/scripts/Makefile.spl:349: recipe for target 'spl/u-boot-spl' failed
| make[2]: *** [spl/u-boot-spl] Error 1
| /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git/Makefile:1399: recipe for target 'spl/u-boot-spl' failed
| make[1]: *** [spl/u-boot-spl] Error 2
| make[1]: Leaving directory '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/build'
| Makefile:150: recipe for target 'sub-make' failed
| make: *** [sub-make] Error 2
| make: Leaving directory '/home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/git'
| ERROR: oe_runmake failed
| WARNING: /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/temp/run.do_compile.11879:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/sunny/Projects/Siemens/Yocto/source/tisdk/build/arago-tmp-external-linaro-toolchain/work/am335x_evm-linux-gnueabi/u-boot-ti-staging/2018.01+gitAUTOINC+8b2f1df4b5-r19/temp/log.do_compile.11879)
ERROR: Task (/home/sunny/Projects/Siemens/Yocto/source/tisdk/sources/meta-ti/recipes-bsp/u-boot/u-boot-ti-staging_2018.01.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 664 tasks of which 662 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
I have also tried to follow the solution given on this link, but SPL/TPL option is somehow not enabled in my menuconfig. Am bit new to ti platform in terms of MLO/Uboot. Please Help. The Image of make menuconfig command is as below.
