Hi I'm using TWL1200ZQCR voltage translator for 3v3 to 1v8.The enable for this signal is active low.I have put a pull down to enable the IC defaultly.When I am trying to disable this IC by making the enable high through GPIO from software,its not getting disabled and when I try a manual pull up it's getting disabled.
The voltage levels are same when trying the both ways.But still the IC is not getting disabled
Has any one experienced the same issue?
