Hi Team,
Could you clarify a difference between "Ambient Operating Temperature" and "Functional Operating Temperature"?
Yaita / Japan disty
Hi Yaita-san,
The "Ambient Operating Temperature" is the recommended temperature range for the humidity sensor.
The "Functional Operating Temperature" represents instead the temperature limits outside of which the humidity sensor accuracy could start to drift.
Prolonged operations outside the "Functional Operating Temperature" can result in fact in a RH accuracy shift as shown in table 11 at page 19.
Please let me know if this reply to your question.
Carmine
Hi Carmine-san,
Thank you for your reply.
However I couldn't catch why temperature range of 71~84℃ isn't recommended from your comment.
Is there any reason that temperature range of 71~84℃ isn't recommended?
Yaita
Dear Yaita-san,
Sorry for the delay in the answer.
The reason why the temperature range of 71~84℃ isn't recommended is due to the fact that in this temperature range the RH accuracy can drift in condition of high humidity, even if the humidity is below the recommended limit of 70%RH. Let me show you same examples:
Please let me know if now is more clear.
Carmine
I know it is an old post but I have some questions regarding this. As stated in the datasheet of the sensor, the heater can be used to decrease the offset after long exposure to high T / RH. How can it be quantified and how long should the procedure be? Is there a document or recommendation that I missed? We must perform tests at 45 C / 90 % for at least 4-5 hours and as I read, there is a possibility of the sensor to drift. If this happens (I don't know how to detect it), for how long should I keep the heater on?
Hope that makes sense and thank in advance.
Mircea
User50775756,
All sensing technologies supported by TI products (which are a lot) can be very easily find and explored using the link below:
Once you find a sensor that fit your needs you can post on e2e using the part number you want to explore.
With respect to your objective of testing food, you need to quantify on physical parameters. such as temperature and / humidity.
