After I ran demo, I want to check the EDMA register in CCS. But I can't see most of the registers. Would you pls kindly advise what is missed?
Hi Chris,
The address region in your snapshot belongs to DSS_TPCC instance. Please check the Register map for EDMA TPCC to see the valid registers for this module.
Valid address are at offset of 0x0, 0x,4, 0x200.. and so on.
EDMA chapter can be found in Technical Reference Manual on product page of IWR1443
Thank you,
Vaibhav
Chris,
Address of DSS_TPCC in CCS view is right. So you are looking at the right location.
However that location onwards you will only see the valid registers populated and accessible. I tried to add a snapshot in last post, seems like it did not show up.
I will try it below again:
Valid offsets addresses to look for at DSS_TPCC's base address are in Table 11-19 : (including a snapshot below hope it shows up)
Vaibhav
