Hi champion,
My customer is looking at the mmwave demo in mmwave_sdk_01_00_00_05. I got a question about the MMWave_spawn funciton in the code. This function is registered to rlDevicePowerOn in below code.
/* Initialize OSI Queue Interface */ RlApp_ClientCtx.osiCb.queue.rlOsiSpawn = &MMWave_spawn;
- Inside this function it saved input function point and parameter in gMMWave_MCB.ptrSpawnFxnFreeList, and then post a semaphore to other task. My questiton is when
MMWave_spawn is called and what is the funciton point and parameter it used.
static rlInt32_t MMWave_spawn ( RL_P_OSI_SPAWN_ENTRY fxn, const void* pValue, uint32_t flags ) { MMWave_SpawnFxnNode* ptrSpawnFxnNode; uintptr_t key; int32_t retVal = 0; /* Critical Section: The spawn free list is a critical resource which is accessed * from multiple contexts */ key = HwiP_disable(); ptrSpawnFxnNode = (MMWave_SpawnFxnNode*)MMWave_listRemove ((MMWave_ListNode**)&gMMWave_MCB.ptrSpawnFxnFreeList); HwiP_restore (key); /* Did we get an entry? */ if (ptrSpawnFxnNode != NULL) { /* YES: Populate the entry */ ptrSpawnFxnNode->spawnEntry = fxn; ptrSpawnFxnNode->arg = pValue; /* Critical Section: The spawn active list is a critical resource which is accessed * from multiple contexts */ key = HwiP_disable(); MMWave_listAdd ((MMWave_ListNode**)&gMMWave_MCB.ptrSpawnFxnActiveList, (MMWave_ListNode*)ptrSpawnFxnNode); HwiP_restore (key); /* Keep track of the number of spawn messages which have been received */ gMMWave_MCB.spawnCounter++; /* Wake up the mmWave execution thread */ SemaphoreP_post (gMMWave_MCB.linkSemHandle); } else { /* Error: No span free node was present. This can happen if all the spawn functions * have been taken up and the execute mmWave control API has not been invoked. Increment * statistics to report this condition */ gMMWave_MCB.spawnOverflow++; /* Setup the return value to indicate an error. */ retVal = -1; } return retVal; }
2. why we define the spwan list size to 4 (MMWAVE_MAX_NUM_SPAWN_LIST)? In which case we need to use this list to save more than one funciton call.
