Other Parts Discussed in Thread: IWR1443BOOST, , AWR1642
With respect to this video: https://training.ti.com/automotive-short-range-radar-demonstration-using-ti-awr-sensors?cu=1135109
Could you provide me with how the Raw ADC data was captured and stored for later post processing or how it can be done?
I have been looking at both MMWAVE-DEVPACK and TSW1400EVM but I am concerned that the 1 GB memory is insufficient for a 15-30 minutes test.
Previous posts that I have looked at:
https://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/p/632001/2331276?tisearch=e2e-sitesearch&keymatch=mmwave%20adc%20recording#2331276
Hello Maxim,
You are right, you cannot have live streaming capture using TSW1400. It can only support a one-shot 10sec capture. For streaming you would need different solution with much higher bandwidth and storage capacity. We presently don't have a ready made solution for this.
Vivek
https://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/p/604340/2224218
Hello Jon,
The Out of Box demo example sends such post processed data over the UART port of the mmWave device and which get sent over USB out of the EVM board. That would be a good option to get data from the device. If you do have the option of recording over machine like PC which will allow you to collect the data over USB interface then you can try it with our IWR1443BOOST or AWR1642BOOST EVMs.
Data is continuously streamed over the usb interface of EVM when Out of Box demo is invoked and it can be saved for further processing provided the capture machine has enough data space. Typically this should not be an issue with PC based captures.
