Hi team,
My customer is using LM96080 and they found that in one occasional power-up, one of the 7 channels might have readback failure. Other 6 channels are all OK.
Could you kindly check whether we have met same issue before?
Thank you!
Hi team,
Thank you!
Hi Luke,
We will need more information on what they are doing.
If they power on and immediately try to make a reading they will get bad data. The Value RAM conversion results (addresses 20h - 29h) and Value RAM WATCHDOG limits (addresses 2Ah - 3Dh) are not reset and will be indeterminate immediately after power on.
Are they are doing some set up before making the readings?
Mike
HI Luke,
There are three ways to reset the LM96080.
Power Cycling will reset everything.
Taking NTEST_IN/Reset_IN low for more than 50ns does the same as a power cycle.
Writing the INITIALIZATION bit will reset the register listed in the list on page 14 of the datasheet. The Value RAM conversion results and the Value RAM WATCHDOG limits are not reset.
Mike
