Hello
I am new to this forum, I have generic questions about apply temperature sensor to remotely detect the temp of flowing liquid.
I am consider to measure the temperature of hydraulic oil in automotive application.
1. The oil is not in static state will flow at unknow speed mix with air under atmospheric pressure?
2. For normal RTD or NTC temperature sensor, the accuracy is pretty bad due to the distance away from the fluid and limited volume of oil reach the front part of sensor.
3. What TI sensing technology you would recommend for this application which enable better accuracy and remote detection through metallic housing? Could Ultrasonic sensor do the job?
Many Thanks
Andrew
