I am interested in knowing if anyone in the community has experience in interfacing TDC1000, TDC7200 with either Arduino or Raspberry Pi. I want to explore potential application of sensing ambient wind speed.
Nair
We (TI) haven't done any work on it.
Good luck!
Thanks for the document.
I'm following that design and replacing the processor with and Arduino board for the prototype phase.
Hey ,
I'm still on first stages of development, but I'd be happy to know what issues are you facing when trying to interface with the UNO?
Maybe we can share ideas on how to do this correctly.
Ran.
@user4575707, I have to get the TDC1000 first and looking at the two eval boards at the moment:
www.ti.com/.../tdc1000-c2000evm & www.ti.com/.../tdc1000-tdc7200evm
However, I may go with a simple breakout board if I can find it. What board are you using?
My intention is to post everything to GitHub once I get started.
I think for better than uS mesurments, likely a better MCU will be required. I don't think the issue is Arduino, but likely is the Atmel 328 or 32u4 IC. Something like SAMD would be better. I'll take a look at that PDF and try to put something together once I order the parts?
As I see it , If you plan to use the TDC7200 (timer) then you don't need a better MCU then the Arduino.
The timer will measure the TOF , and MCU will just read the results from its registers.
