We would like to be able to change profileCfg constant, such as startFreqConst, at runtime instead of compile time. For example, the radar has a default profileCfg with a set of chirp parameters decided at compile time. Then as it power up, we want to send it a command to change its startFreqConst or freqSlopeConst to a different value. Is it enough to do the following?
rlProfileCfg_t profileCfg;
MMWave_getProfileCfg(known_profile_handle, &profileCfg, &errCode);
profileCfg.startFreqConst = new_value;
Would the above code be enough for new_value to take effect, or will I need to delete the old profile and then use MMWave_addProfile(..., &profileCfg, ...)?
Thank you.
