TS3A5017: TS3A5017
Part Number: TS3A5017
Other Parts Discussed in Thread: TS3A5018
Hello sir,
Thanks for your time. I'm wondering what is TS3A5017 RthJC value cause I want to calculate the power consumption and temperature.  Could you please kindly provide it to me? Thank you so much!
Ann Lien
  • Ann,
    The power consumption for the TS3A5018 across full temperature range -40 to 85 deg C is <10uA.  You can see in the I+ spec in the datasheet.
    You may use the thermal data for the TS3A5018 for the TS3A5017 for the thermal resistance between the junction to case Rthjc.
    Here is another post related to calculating max junction temperatures based on signal switch power dissipation.
    Thank you,
    Adam
  • Hi Adam,
    Thanks for your big help! It's really a great answer for my customer!
    Ann Lien
