Other Parts Discussed in Thread: TLV320AIC3204, , TLV320AIC3206
I'm not sure what to do with GND_SENSE. I'm using a TLV320AIC3204 codec with the TS3A227E and I don't see a GND_SENSE input. What is it used for?
Thank you
Thank you
Hello Eric,
The GND_SENSE pin is a feedback signal which goes back to the Codec because the G ring on the audio jack doesn’t see true ground, as the image below shows:
The switches have some resistance (circled in blue), therefore the G ring could have some voltage value on it. The concept behind the GND_SENSE pin is that it should feedback into the Codec to help mitigate out any introduced crosstalk. This is why it is present whether your audio jack has a M ring or not.
Thank you,
Louie
