Team,
Do you have a device that is pin-to-pin with TC7SB385FU?
Nic
Hi Nic,
This is a 1 ohm analog switch. Did you try the parametric search? I was able to narrow the list to 14 devices pretty quickly there (1 ohm, 1 channel devices).
It looks like this is an SPST switch, so I focused on those and quickly found TS5A3166 and TS5A3167 - I'd have to look into it further to be certain if one of those fit the bill, but switches aren't really my area of expertise (this ended up in the logic team for some reason).
If you need additional help, I can ask the switch/mux apps folks to take a look at this thread.
