Other Parts Discussed in Thread: TINA-TI,
Tool/software: TINA-TI or Spice Models
TPS50601-SP The data sheet states that if you leave the RT pin floating, then the SYNC pin will output a specified frequency signal (500k)
My customer is using OrCAD PSpice 16.6 and he is not seeing this in the model. Is this something that was not designed into the original model as is there a problem in simulating the proper output from the SYNC pin? Is there an issue with the model? I have looked at the customer’s model and do not see any issues with how it is configured.
Thanks for your help with this!
Richard Elmquist
