Hello!!
Good Day!!!
I am using LDC1612 IC in one of my application. (attached the coil sensor specifications which am using, designed with the help of TI's Webench Coil designer tool).
As I am unable to measure the AC parallel resistance, RP of the coil am using, please suggest any method or ways to relate/derive the required drive current with the help of DC resistance of the coil, as it is easier for me to measure. (As in the data sheet, the drive current register codes are listed down against the Rp of the sensor. It will be much helpful, if I get the look up table for the drive current registers against the Coil sensor's DC resistance or any theoretical calculations to derive the Rp using the DC resistance of the coil.
