We have designed a BT board based on CC2564MODNCMOET for one of our projects with third party design house. Our third part design house has chosen the following antenna design recommend by TI http://www.ti.com/lit/an/swra117d/swra117d.pdf . With this antenna, we are able to establish connection, but the range is less than 10ft. If the circuit is kept in a enclosure, it drops further.
In parallel, we tried our code on CC2564 Audio sink kit from TI which uses http://www.ti.com/lit/an/swru120b/swru120b.pdf (Invertef F antenna), the range is very good.
After Googling on understanding antenna (quite a complex stuff), i bumped into TI document which says inverted F-antenna has better efficiency but i have seen other
TI modules which uses the same antenna design we have selected.
Now our design engineer is not clear as to what is the issue for losing on range and even i am not sure what to ask or where to debug as i am not HW centric person.
Few things which i have checked and experimented are:
1. Check the schematic given by TI and our schematic, they are both same. Designer has followed reference schematic.
2. Tweak the capacitors values around antenna, didn't show any improvement.
3. Dimension of PCB antenna followed by our designer is same as TI ref design.
4. Lot of articles talk about ground plan can also cause antenna efficiency to come down. I quite didn't get this, but i do see kind of plane around the PCB antenna.
As i have hit a road block, not sure what else to look for. Looking for help on some pointers and how to debug this further. Thanks a lot in advance
Prashanth
