We want to setup a PER measurement in our production line with CC2564B. The test is done over the air in a RF immunity box.
To check the sensitivity we want to vary the TX output power. With CC2564B the default vector is defined from 12dBm to -23dBm with one at -50dBm.
We were able to change the actual power vector once after power up, Apply service pack, apply ble add on.
We observed that we only can go down to -35dBm. We observed as well that the step size could be 1dBm. In the datasheet we cannot find the appropriate information
We should have a power vector between -30dBm and -50dBm to avoid physical attenuators in our test system
My question:
- What is the power range we can set for BLE 12dBm downto ??
- What is the step size (even if for HCI_VS_DRPb_Set_Power_Vector 5dBm is written in wiki, we could use 1dBm) ?
- How can I change the default power vector in BHET? For actual Service pack this option seems to be removed
There were already some posts in this support forum regarding this topic. But I couldn't get the necessary information
Kind regards
Joel
There are already several
