I am using A3DP Multirrom Demo.
I have confirmed that the commands RemotePlay and RemotePause are implemented.
However, I have noticed that RemoteVolumeup and RemoteVolumeDown are not implemented in the Demo project.
I implemented it myself, but it did not work and it had a value of 0x08.
How can I use the AVRCP profile to control the volume of my phone on the board?
The results of the RemoteVolumeup and RemoteVolumeDown commands
Source code for RemoteVolumeup and RemoteVolumeDown
int RemoteVolumeUp(ParameterList_t *TempParam) { int nResult; // Ensure that we have an open stream first. if (A3DPOpened) nResult = SendRemoteControlCommand(rcVolumeUp); else { Display("A3DP Stream is not opened yet.\r\n"); nResult = FUNCTION_ERROR; } return (nResult); } int RemoteVolumeDown(ParameterList_t *TempParam) { int nResult; // Ensure that we have an open stream first. if (A3DPOpened) nResult = SendRemoteControlCommand(rcVolumeDown); else { Display("A3DP Stream is not opened yet.\r\n"); nResult = FUNCTION_ERROR; } return (nResult); }
Source code for SendRemoteControlCommand is same as Demo.
int SendRemoteControlCommand(RemoteControlCommand_t Command) { int nResult; Boolean_t ProcessCommand; AUD_Remote_Control_Command_Data_t RemoteCommand; // Ensure that we have an open stream first. if (A3DPOpened) { // Initialize local variables. nResult = 0; ProcessCommand = TRUE; // Initialize common members of the pass through command. // * NOTE * State flag of FALSE specifies button down. RemoteCommand.MessageType = amtPassThrough; RemoteCommand.MessageData.PassThroughCommandData.CommandType = AVRCP_CTYPE_CONTROL; RemoteCommand.MessageData.PassThroughCommandData.SubunitType = AVRCP_SUBUNIT_TYPE_PANEL; RemoteCommand.MessageData.PassThroughCommandData.SubunitID = AVRCP_SUBUNIT_ID_INSTANCE_0; RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)0; RemoteCommand.MessageData.PassThroughCommandData.StateFlag = (Boolean_t)FALSE; RemoteCommand.MessageData.PassThroughCommandData.OperationDataLength = 0; RemoteCommand.MessageData.PassThroughCommandData.OperationData = NULL; // Determine the command and go ahead and build it. switch(Command) { case rcPlayPause: // Verify that we do not have another play/pause pending. if (StreamState != ssPending) { if (StreamState == ssStarted) RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_PAUSE; else RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_PLAY; StreamState = ssPending; } else { // Command already pending so don't process this request. ProcessCommand = FALSE; } break; case rcPlay: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_PLAY; break; case rcPause: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_PAUSE; break; case rcNext: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_FORWARD; break; case rcBack: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_BACKWARD; break; case rcVolumeUp: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_VOLUME_UP; break; case rcVolumeDown: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_VOLUME_DOWN; break; case rcSampleRateUp: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_0; break; case rcSampleRateDown: RemoteCommand.MessageData.PassThroughCommandData.OperationID = (Byte_t)AVRCP_PASS_THROUGH_ID_1; break; default: // Unsupported - flag error. nResult = INVALID_PARAMETERS_ERROR; break; } // Continue only if we have a command to process. if (ProcessCommand) { // Proceed only if the AVRCP command is supported. if (!nResult) nResult = AUD_Send_Remote_Control_Command(BluetoothStackID, A2DPRemoteBD_ADDR, &RemoteCommand, 0); if (nResult > 0) { // Now we must send the button-up command to finish up. RemoteCommand.MessageData.PassThroughCommandData.StateFlag = TRUE; nResult = AUD_Send_Remote_Control_Command(BluetoothStackID, A2DPRemoteBD_ADDR, &RemoteCommand, 1000); if (nResult > 0) { Display("AVRCP command sent successfully.\r\n"); nResult = 0; } else { DisplayV("AUD_Send_Remote_Control_Command() Failed: %d\r\n", nResult); nResult = FUNCTION_ERROR; } } else { DisplayV("AUD_Send_Remote_Control_Command() Failed: %d\r\n", nResult); nResult = FUNCTION_ERROR; } } } else nResult = FUNCTION_ERROR; return (nResult); }
