If so, how much does the process cost, and how long does it take?
Virgil.
Virgil.
Hi Virgil,
You will need hardware certification for FCC and CE .
You can get in touch with 3rd party certification houses like Underwriter Laboratories or TUV at your location to get the pricing.
If you are using TI BLE stack, you will have to undertake an "EPL" or "End Product Listing" from the BT SIG , which will grant the permission to use the BT Smart Logo on your product.
You can find more info in the below link.
http://processors.wiki.ti.com/index.php/How_to_Certify_your_Bluetooth_product
http://processors.wiki.ti.com/index.php/PTM
http://processors.wiki.ti.com/index.php/FCC_ETSI_Test
I would also recommend you to follow the layout guidelines as per below links.
http://www.ti.com/lit/an/swra367a/swra367a.pdf
http://www.ti.com/lit/an/swra380a/swra380a.pdf
http://www.ti.com/lit/an/swra236a/swra236a.pdf
Vijay
