I wanted to send the Service Pack to an CC256XQFNEM with CC256x Bluetooth Hardware Evalutation Tool.
I use an usb/serial converter from FTDI.
I sent the last SP, the CC2560B V1.2.
I disabled sleep mode with Modify SP.
I choose the good Serial Port and Baud rate.
But after sending SP, Debug Trace show an "COM port timed out"
I checked with an oscilloscope on rx pin if the first byte is sent, it's ok.
I didn't see solution on your forum when an usb/serial converter is used.
How can I solve my problem ?
