I'm using the CC3100 as a sniffer with filters. My main goal is to send to the HOST MCU all the incoming Beacons from a certain SSID. I want to drop all the rest of the received packets.
I started with the example code - "sls_sniffer_with_filters" and saw that Payload filters is not supported yet.
I would like to ask the following questions:
(1) When do you expect that SSID filters will be supported?
(2) Until then, is there any way I can filter incoming packets according to values in certain offsets? (I might implement it manually). If yes, can you please send a code snippet.
Nir
