The situation of my board looks physical broken but it starts with software configuration changing. I'm not sure if it's just coincident.
The situation is: I failed to load the code, also failed to Format or Get Version using Uniflash. Following another thread to check FTDI loopback (by short the J6&J7), the FTDI is working OK (I can see echo on Tera Term). Look CC3200 itself has some problem and not responding.
The operations before it 'broken' were: Firstly I tried to create a new workspace to start from fresh to eliminate some code error. I follow the startup steps and everything looks fine. At the step of debugging, it says cannot connect to the device. I tried to go back to the original workspace but still cannot connect. Then I tried to use Uniflash and all operations fail.
It seems the board just broken but it was working fine before I created the workspace. Is it possible any software configuration results this?
