Hi, I use the example from TI-RTOS, as shown below
When I run it and set breakpoints to debug it, I find that the code can only run to EasyLink_init(EasyLink_Phy_50kbps2gfsk);,as shown below. That is, it cannot run the code after this function.
I use XDS100V3 and SimpleLink™ Sub-1 GHz CC1310 Evaluation Module Kit.
What is wrong with this example? Is there something wrong in my setting? Thank you.
