Hi Team,
I am trying to run the WakeOnRadio example code by changing different rate Word values to get different data rate.
However, it only works till as low as 4.8 kbps
When I try to run for 2.4 kbps or 1.2 kbps or 625 bps the receiver is not responding i.e. it is not receiving any packets sent.
Please suggest solution or the reason why it is not working when the Errata sheet mentions that the data rates supported are between 2.4 kbps and 100 kbps
