Hi all,
I'm using "Sensor" & "Collector" examples to build a PAN network. In sensor code in the sensor_process. I'm trying to scan a RFID and transfer that to collector. The RFID reading part was developed by me in a single function. The RFID is a 64 bit integer. There are no errors or warnings when I built the project. I also developed the RFID reading code in a example project (empty) it worked fine.
The problem occurs when I integrate it to sensor example project. I followed the debugging steps and find out it crashes,
Void main() >>>>>> taskfxn >>>>> ICall_createRemoteTasks() >>>>>>> Task_restore(keytask)
It seems its not resotring the keytask. I want a solution please. ASAP.
This is the screenshot of console when error occurs,
Thank you
Dulip
