[FAQ] TI-API: v2 Backlog advanced ship notice (ASN) API error codes and meanings (part 1 of 2)
Part Number: TI-API
What do the v2 ASN API error codes mean?
  • Scenario Error details Remediation steps
    Missing Identifier
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0010",
    			"type": "ERROR",
    			"reason": "Missing Identifier",
    			"message": "The identifier customerPurchaseOrderNumber, wayBillNumber, or orderNumber cannot be null or empty.  Enter a valid Identifier and resubmit request."
    The identifier cannot be null or empty. Enter one valid customerPurchaseOrderNumber or wayBillNumber or orderNumber and resubmit the request. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Only One Identifier Required
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0011",
    			"type": "ERROR",
    			"reason": "Only One Identifier Required",
    			"message": " Only one of the identifiers customerPurchaseOrderNumber, wayBillNumber, or orderNumber is required. Enter only one of the valid Identifiers and resubmit request."
    Only one identifier is required. Enter one of the following valid identifiers: customerPurchaseOrderNumber or wayBillNumber or orderNumber and resubmit the request. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Invalid requestCommercialInvoicePDF or requestWaybillPDF
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0040",
    			"type": "ERROR",
    			"reason": "Invalid requestCommercialInvoicePDF or requestWaybillPDF",
    			"message": " requestCommercialInvoicePDF or requestWaybillPDF – X must have value of either true or false. Field will default to false."
    requestCommercialInvoicePDF or requestWaybillPDF value must be true or false if the PDF is needed. Enter X to receive a PDF; otherwise the field will default to false. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    TI API unavailable for scheduled system maintenance
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0500",
    			"type": "ERROR",
    			"reason": "TI API unavailable for scheduled system maintenance",
    			"message": " This TI API is currently unavailable due to system maintenance. Please resubmit the request after maintenance is completed or contact TI API Support (https://api-portal.ti.com/support) for more information."
    TI server maintenance in progress and is currently unavailable. Attempt to resubmit the request at a later time. If the issue persists, contact TI customer support (Submit Request).
    No shipment data found with customerPurchaseOrderNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-020",
    			"type": "ERROR",
    			"reason": "No shipment data found with customerPurchaseOrderNumber",
    			"message": "Verify and correct the customerPurchaseOrderNumber or use the orderNumber or wayBillNumber and resubmit request."
    Shipment data is not found. Enter a valid customerPurchaseOrderNumber or use either orderNumber or wayBillNumber. Only completed orders will have shipment data available. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    No shipment data found with orderNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0021",
    			"type": "ERROR",
    			"reason": "No shipment data found with orderNumber",
    			"message": "Verify and correct the orderNumber or use the customerPurchaseOrderNumber or wayBillNumber and resubmit request."
    Shipment data is not found. Enter a valid orderNumber or use either customerPurchaseOrderNumber or wayBillNumber. Only completed orders will have shipment data available. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    No shipment data found with wayBillNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0022",
    			"type": "ERROR",
    			"reason": "No shipment data found with wayBillNumber",
    			"message": "Verify and correct the wayBillNumber or use the customerPurchaseOrderNumber or orderNumber and resubmit request."
    Shipment data is not found. Enter a valid wayBillNumber or use either customerPurchaseOrderNumber or orderNumber. Only completed orders will have shipment data available. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Shipment is still in process
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0023",
    			"type": "ERROR",
    			"reason": "Shipment in process, ASN information unavailable at this time",
    			"message": "Shipment information is unavailable at this time. Please try again at a later time."
    Shipment data is not found as shipment is still in process. Please try after some time. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Shipment is complete, ASN is not available at this time
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0024",
    			"type": "ERROR",
    			"reason": "Shipment complete, ASN information unavailable",
    ASN info is not yet ready. Please try after some time. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Invalid soldToAccountNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0030",
    			"type": "ERROR",
    			"reason": "Invalid soldToAccountNumber",
    			"message": " soldToAccountNumber is incorrect.  Verify and correct the soldToAccountNumber and resubmit request."
    The soldToAccountNumber is not valid. Enter a valid soldToAccountNumber. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Missing soldToAccountNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0031",
    			"type": "ERROR",
    			"reason": "Missing soldToAccountNumber",
    			"message": "The soldToAccountNumber cannot be null or empty. Enter a valid soldToAccountNumber and resubmit request."
    The soldToAccountNumber is missing and cannot be null or empty. Enter a valid soldToAccountNumber and resubmit the request. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    Missing business partner's soldToAccountNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0032",
    			"type": "ERROR",
    			"reason": "Missing business partner's soldToAccountNumber",
    			"message": "The Business Partner's soldToAccountNumber cannot be null or empty.  Enter a valid soldToAccountNumber and resubmit request."
    The business partner’s soldToAccountNumber is missing and cannot be null or empty. Enter a valid business partner’s soldToAccountNumber and resubmit the request. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    	"errors": [
    			"type": "ERROR",
    			"reason": "Missing business partner",
    			"message": "Business Partner cannot be null or empty.  Enter a valid Business partner and resubmit request."
    The Business Partner is missing and cannot be null or empty. Enter a valid Business Partner and resubmit the request. If further assistance is needed, contact TI API Support (api-portal.ti.com/support).
    View v2 Backlog advanced ship notice (ASN) API error codes and meanings (part 2 of 2)
