Other Parts Discussed in Thread: LMV226, LMV225
Can I use resistive tap instead of coupler for this part?
That's what I suspected, but the reason I doubted is that a resistive tap method is not mentioned in the datasheet. For example, in the datasheet of LMV225/LMV226, it's specifically mentioned that LMV225 is suited for resistive tap and LMV226 is suited for connection with a directional coupler.
The attached image is what I have in mind
Hi Amin,
The LMH2100 should also work with a resistive tap and the image looks to be the correct way of doing a resistive tap. One thing to note is that you should make sure that you choose a resistor value such that you get the correct amount of attenuation needed for your design.
David Chaparro
