Part Number: LT1014
Hi Sir,
A customer has a inquire about stability when LT1014 is used as attenuator.
The application note warns that using op amps as attenuators can cause instability when tageting high frequency applications in tens of MHz range.
But we applied the LT1014 to the circuit that senses the output through the PWM driver in the 50kHz range, and ask for advice on whether this cause instability.
i want to know stability.
Thanks a lot.
