TLV8542: Output Impedance for Unbiased State
Part Number: TLV8542
Hi Team,
What is the output impedance of the TLV8542 amplifier in an unbiased state?
Asking this question as our customer is using the op-amp in driving the control signal of a switch. In a later state, the bias of the op-amp will be removed (turning it off) but the output will still be connected to a different stage in that certain state. With this we need to know if the output of the op-amp will exhibit a high impedance (which is desired) or if they have to use some kind of diode isolation (but would prefer not to).
To put it simply, the control signaling of the switch is still active, but will be driven from a different source than the TLV8542.
Thanks in advance!
Kind Regards,
Jejomar
