For instance, if I want to observe the effect of change in resistance on voltage waveform, for say 5 different resistor values is there a way to have the 5 plots on the same viewer (kind of like the "History ON" feature in ADS keysight)
Hello Desiree,
Thank you for your inquiry about TINA-TI. Since TINA-TI is a DesignSoft/TINA program, questions are handled by using the DesignSoft support page: http://www.tina.com/technical-support/ .
The DesignSoft/TINA team is very helpful and this is the most direct way for TINA support. Please advise by Reply to this case when the issue has been resolved.
~Leonard
Hey Desiree,
TINA V9 has a parameter stepping function that will do this, my V11 does not so I was not that familiar with it. Lots of good stuff in this slide deck, starting on slide 17 is parallel parameter stepping,
Hi thanks for this! I wasn't aware that parallel parameter sweeping was possible.This worked for me!
