Other Parts Discussed in Thread: XTR108
is it possibble to use XTR108 without serial EEPROM ?
I suppose, that MCU connected to XTR108 will always configure XTR's registers after each power-up. I would like to use four XTRs (each with one 3-wire RTD for temperature measurement) with their SPI bus connected together and tied to MCU. I suspect that it will not be possible with EEPROM connected to each XTR because XTR doesn't have separate SPI interface for communication with EEPROM.
For completness: I will not use current output from XTR108, only voltage output (pin Vout), XTR supplied with +5V on pin Vs, pin Iret acts as GND).
Thank you for answering.....
Zdenek
