Please check unit of PSRR in datasheet.
Is uV/V correct ?
Hey Kura,
Thanks for bringing up the confusing units, I will reach out to our systems team to have this fixed.
All the best,
Carolina
So Kura, what happened is the actual ATE output data is uV/V input referred offset voltage shift with supply voltage, that then converts to a 110dB minimum - that 3uV/V in the max column would be the test limit.
Hey Kura,
This is a confirmed mistake on our part, thank you so much for catching it! This will be fixed in the newest revision of the datasheet.
All the best,
Carolina
Hey Kura,
It is up to the systems engineer but I imagine the change will make both the typical and max spec the same units.
Therefore with that assumption, I believe typ: 1uV/V, max: ±3uV/V.
All the best,
Carolina
P.S. Kai sorry about editing your post, it was accidental!
