[FAQ] How to Select Amplifiers for 4-20mA Field Transmitter Applications
Field transmitter is a general term that encompasses the common industrial process control systems: pressure, temperature, and flow. While pressure, temperature, and flow transmitters each pose distinct design challenges and considerations, some signal conditioning similarities exist between the three.
A sensor will convert the physical quantity (i.e. pressure, temperature, flow, etc.) into an electrical signal. More often than not, the sensors used to detect the aforementioned physical quantities produce a small differential electrical signal that needs to be amplified (i.e. bridge sensors, thermocouples, etc.). An instrumentation amplifier is used to amplify the signal and perform the differential to a single ended conversion.
Figure 1 - Simplified field transmitter implementation
The amplified signal is then used to create the renowned 4-20mA current output to transport the sensor data to a remote processer. There are several ways to create this 4-20mA output. For example, a common implementation is to take the analog signal from the instrumentation amplifier and convert it to the digital domain using an analog-to-digital converter (ADC). The digital information is processed by a microprocessor that then controls a digital-to-analog converter (DAC). The DAC output is then used to create the 4-20mA current output.
The voltage to current conversion can be done discretely using an op-amp and some external components, but the simplest way is to use a 4-20mA transmitter (XTR) that integrates the op-amp and offers some additional functionality (i.e. excitation currents, reference voltages, error detection flags, etc.). The XTR amplifier can be easily interfaced with a DAC or directly with the instrumentation amplifier as shown in Figure 1.
Table 1 shows some recommended instrumentation amplifiers for interfacing with many pressure, temperature, and flow sensors. The requirements here are high common-mode rejection (CMR), low offset and offset drift, low noise, and low power.
Table 1 - Instrumentation amplifiers for field transmitters
Device
CMRR (min, G=1000)
Input offset voltage (max)
Input offset drift (max)
Noise density
Quiescent current (typ)
INA823
100 dB
100 µV
2 µV/°C
21 nV/√Hz
250 µA
INA819
140 dB
35 µV
0.4 µV/°C
8 nV/√Hz
350 µA
INA821
140 dB
35 µV
0.4 µV/°C
7 nV/√Hz
650 µA
INA317
100 dB
75 µV
0.3 µV/°C
50 nV/√Hz
50 µA
Table 2 shows some recommended XTR devices for 2 and 3 wire applications. XTRs offer an easy, ready to use solution for creating a 4-20mA transmitter. Also visit [FAQ] How do I choose a 4-20mA transmitter? for more details.
Table 2- XTR devices for field transmitters
Device
Functionality
Supply voltage range
Features
XTR115
2 wire
7.5V – 36V
5 V regulator and 2.5 V reference
XTR111
3 wire
8V – 40V
Configurable regulator 3V -5 V
XTR305
3 wire
10V – 40V
User selectable current/voltage output, output error flags, thermal protection
Table 3 shows some recommended op-amps for a discrete implementation of the 4-20mA function. The requirements here are low power, low offset, and offset drift.
Table 3- Op-amps for field transmitters
Device
Bandwidth
Offset voltage drift (typ)
OPA391
24 µA
1 MHz
45 µV
1.00 µV/°C
1.7V – 5.5 V
OPA187
100 µA
550 kHz
10 µV
0.001 µV/°C
4.5V – 36 V
OPA333
17 µA
350 kHz
10 µV
0.02 µV/°C
1.8 V – 5.5 V
For useful resources, please make sure to check out the following content.
How to Select Amplifiers for Pressure Transmitter Applications
[FAQ] Designing with 4-20mA current loop transmitters (XTRs): FAQ links
[FAQ] How do Instrumentation Amplifiers (INAs) fit into my design?
TI Precision Labs – Instrumentation Amplifier Video Curriculum
TI Precision Labs - Amplifiers: Introduction to 4-20mA current loop transmitters
Why precision matters with fully differential amplifiers
