Part Number: INA226
Other Parts Discussed in Thread: INA228, INA229, INA239, INA238
Hi
Part Number: INA226
Hi
Hello Abishek,
Thank you for using the TI forum. We have a convenient design tool/app note that can help you select the proper shunt resistor based on your system needs, which can be found at https://www.ti.com/lit/an/sboa511/sboa511.pdf. Note that the link to the design tool is in the introduction.
We do not share the internal reference, but all relevant specifications are in the datasheet. If you are interested in error sources, please see our training series at https://training.ti.com/ti-precision-labs-current-sense-amplifiers-introduction-different-error-sources
Also, there is an error calculator tool on the bottom of the product page:
One more note is that you may want to look into using the INA228 (I2C) or INA229 (SPI), as these devices have higher accuracy/resolution. If you are looking for a lower cost solution with less accuracy, then you can also look at the INA238 (I2C) or INA239 (SPI).
Here would be the estimated error for the INA228 with the same settings as above:
