Part Number: LMH5401
Other Parts Discussed in Thread: LMH6401
Team-
Supporting a wide-band signal chain application with the LMH5401 in the front end. It needs to be DC accurate; the ADC has some internal offset correction capabilities, but not sure if it is enough to cover the contribution of the LMH5401 and if additional temperature compensation is required.
The data sheet specifies the input offset voltage (+/-5 mV,max), but doesn't appear to spec offset drift.
Figure 54 has a graph of differential DC offset voltage vs. temperature, but not sure if we can rely on this without more substantial statistics.
We are concerned with operating from 0-60C, which appears to be pretty flat temp co.
Any other comments or data you can provide on this topic would be appreciated.
-Steve
