Op-amp selection assistance
Other Parts Discussed in Thread: THS3491, OPA2677
Hello Guys,
Good day.
Please help on selecting an Op-amp for our customer requirements below.
"I'd like to amplify the signal (in range from ~100kHz to ~4MHz) from my signal generator (Hantek DSO2D10), to be able to send it to a simple antenna (50 Ohm impedance, maybe just a coax cable will also work) and get around 50w of emitted signal power. The device will be in a Faraday cage to avoid possible interference with people already using those frequencies.
I'm not trying to build any kind of a radio transmitter or so. My goal is to just emit various frequencies in the air and inspect how those frequencies affect test objects (in near vicinity, around 1 or 2 feet away) in resonance with those emitted frequencies.
Which of your op amps would you use if you were to build such a thing?"
Thanks and regards,
Art
  • Hi Art,
    We can't give you 50w of power, but the closest we have is probably the THS3491. You may want to look into a power op amp or RF power amp for this application. 4MHz doesn't really require a high speed amp, so if you would like I can forward this to another apps team to get you a better recommendation from one of those portfolios. The THS3491, while not exactly designed for this task, is pretty capable so take a look and let me know what you think. Sounds like a fun experiment.
    Sam
  • Hello Sam,
    The customer reviewed the suggestion and for them it looks like a good choice. However, they noticed that its a Current Feedback Amplifier and wanted to know reasoning behind a CFA suggestion?
    Thanks and regards,
    Art
  • No reasoning, it is just that the CFA apps often require a lot of output power and that is what you are asking for. Also, for lower supplies, the OPA2677 dual puts out a lot of current for another CFA.
  • Hi Art,
    Michael is right on point, might want to check out that OPA2677 he suggested as well.
    Sam
