OPA4188: OPA4188AIPWR
Part Number: OPA4188
I am using OPA4188AIPWR for low side current sensing circuit. In the normal condition output I am getting is OK but if I introduce noise at the input I am not getting the exact waveform it's a noisy one. I am using first order low pass filter at the output of the OPAMP. Is there any other filter design I can use so that I get the desired waveform. If you suggest it would be helpful. FYI The output of the circuit goes to ADC.
Ajay Sahu
  • Hello Ajay,
    Are you able to share your OPA4188 schematic, power supply arrangement and observed waveforms? That would provide us much more information to consider. Since this is a low-side sensing circuit just how low does the output voltage have to go?
    If filtering is applicable we likely could configure the low-side voltage sense circuit to include an active low-pass response to help reduce the noise.
    Thanks, Thomas
    Precision Amplifiers Applications Engineering
  • Hi Thomas,
    My issue has been resolved.
    Ajay
