Part Number: LMH3401
Other Parts Discussed in Thread: TINA-TI,
How to calculate the output noise?
What is the function of noise figure?
Can we calculate the output noise according to the noise figure?
We have Tina-TI and PSpice models/simulation examples located at this link. Section 10.1.2 in the LMH3401 datasheet goes over output noise analysis calculations for this part, but we also recommended simulating using the provided models.
The noise figure is relates to the signal to noise ratio of the device. It is 10log the ratio of the input signal to noise and the output signal to noise.
The relationship between noise figure and the op amp noise sources, resistor noise, and noise gain.
Noise Figure (NF) parameters are commonly used for integrated solutions. The input referred noise of 1.4nV/sqrtHz and input current noise of 2.5pA/sqrtHz for the device will help with determining the minimum amount of signal that can be detected as well.
Here are more resources:
1) General Noise Analysis of High Speed Amplifiers
2) Noise Specifications of Amplifiers
3) Calculating Noise Figure in Amplifiers
Thank you,
Sima
