Hello Expert,
My customer has question for OPA549.
They are planning to use OPA549T for their products but they are facing supply issue with this.
Then, they plan to use OPA549S as OPA549T because they has equipment to do lead forming.
However, For this procedure, they'd like to get advice from TI.
They can do lead forming but they don't have enough knowledge about how to check whether there is damage on bended device.
Would you provide advice for confirming damage when they do lead forming for converting OPA549S to OPA549T?
Kazuki Kuramochi
Kuramochi-san,
The OPA549 lead forming is accomplished overseas at an assembly facility so we don't have the ability to observe the process firsthand at this location. Nonetheless, we do see what the finished OPA549 product looks like when we have received devices. Therefore, about all I can provide are some general comments.
First and foremost make sure that the OPA549 leads are formed to conform with the KV ( R-PZFM-T11) mechanical data sheet for the plastic flange-mount package included near the end of the datasheet. The drawing shows the lead bend points, but unfortunately no information about the bend radius dimensions. The bend radiuses shown in the mechanical drawing do look similar to what is obtained with the actual device so the goal should be to achieve similarity between them.
A clean bend should not show any stresses or disturbances of the lead surface plating. If the bends are too severe that may happen and could be an undesirable result.
Regards, Thomas
Precision Amplifiers Applications Engineering
Thomas-san,
Thank you for your kindly explanation.
I understand and will let you know when I have further question.
Kazuki Kuramochi
