I'm trying to simulate output noise on a single output (not differential noise) of THS7530 but I don't understand results.
Simulation schematic is below:
Noise at OUTp at 1MHz is about 139.9 nV/rac(Hz) for a gain of 33 dB. Input noise in this cas is about 3 nV/rac(Hz).
In the datasheet, the input noise curve is below:
Input noise is about 1.2 nV/rac(Hz) at 1MHz.
So or the noise gain is not the same as the signal gain of 33 dB in my case (but I'm not able to calculate the NG for THS7530 because the loop is inside the component) or the noise is not include in the spice model.
Could you explain me what is wrong, please?
