Part Number: OPA2991
Other Parts Discussed in Thread: TLV9102,
Hi
What is the procedure to measure the CCMR of 130db on this amp?
Thanks for your help
Hello Druilhe,
Please see this Troubleshooting Tips Op Amps - CMRR video for the procedure.
Please note the test conditions from the datasheet:
For the graph in the DS:
All the best,
Carolina
I don't understand the video. For an AOP power supply test V+=+30V V-=0V output voltage 15V what is the voltage injected on VOC?
You will find attached a simulation.
Thanks for your help.
Hey Druilhe,
I thought you were measuring it in a laboratory setting. In a simulation setting you may use AN1516: https://www.ti.com/lit/an/snoa475f/snoa475f.pdf
The document uses TLV9102 as an example but the OPA2991 may be dropped in as a replacement. The circuits are embedded in the document.
All the best,
Carolina
