THS4551: THS4551
Part Number: THS4551
Other Parts Discussed in Thread: ADS127L11
I am designing a board with THS4551 in a few configurations: FDA with -3dB around 200kHz, MFB Bessel stages, ADC (ADS127L11) driver.
It was very-very helpful and easy to base my simulations on the TINA simulation files that the datasheet points on.
Found also related thread on E2E (https://e2e.ti.com/support/amplifiers-group/amplifiers/f/amplifiers-forum/953107/ths4551-ths4551-model-for-tina?keyMatch=THS4551+RTM+MODEL).
The TINA model from July 2016 is mentioned in this thread. I was almost sure the model in the downloaded files is from June 2016.
Checking, I found that the loop gain simulation file uses June/2016 model and the other files use July/2016 model.
Exchanging the models (the parts) in the schematics, I got different results above 200 – 220MHz.
Comparing the scripts (the models) by text editor, I found they are slightly different.
Which of them you recommend to use?
Sincerely,
Mikhail
